LS1notFOUND
EDIT ADDED INTRO:
Created this thread because there really is not a step by step write up on setting this up for our vehicles, and the info is splattered among Ultraguage, MYlink etc threads and this may help some avoid that "fear of the unknown" part of it.
[CLICK ANY IMAGE TO ENLARGE]
Vehicle Info:
-This was done on a 1.8L 5Spd Manual, LS with Premium Sound (NOT Connectivity pkg)...I refer to it as "uniquely optioned" some say "option-less"
Hardware:
-VERIZON DROID4
-BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool
Software:
-ANDROID Version 4.0.4 (ICS/Icecream Sandwhich)
-Torque Pro
Always have been helping friends and such with their cars and the biggest pain was reading the check engine light (clearing it), or troubleshooting a misfire with out a scan tool. Its always better to have look than take it into a shop totally blind and figure out if its something you can do, or if its deep within.
So I purchased this:
Some sort of scanner really is becoming a must have for the toolbox, and since most are now using phones/tablets that rival the computer power of desktops, use its potential.
To qualify for SuperSaver Shipping (shipping was going to be about equal) I also bought an Oil Filter for the 1.8L Sonic:ACDelco PF2257G Oil Filter
Now I was skeptical on the price and the horror stories I heard about cheap import models, but this sold through a company in Wisconsin. It was not shipped from somewhere in Japan or China so I went ahead a purchased it.
The reviews are pretty positive and most negative reviews are from Ford owners, ScanGuage has this issue also of needing a 12volt source ran to it because some OBDII ports simply dont supply power, or enough...but that luckily doesn't pertain to us (AT LEAST 1.8L models, have not tested on 1.4L or RS models.)
Its actually built pretty good for a "DIY consumer" grade product...I wouldn't want to drop it or use it commercially (ok maybe I would as a quick product for the top of the tool box), we'll say its "not SnapOn but better than Harbor Freight".
First things first, open the package is easy, its in ziplock bag.
-Put car key-on engine off, plug it in (you can start it too but at this point why waste the fuel).
-The Device will blink some lights and ultimately just show one solid red light.
-Turn on Bluetooth
On my DROID4 it appeared nearly instantly, "OBDII" in the available devices section, password on my unit was 1234, it may be 0000 or 5678 etc. You may or may not see the unit acknowledge the pairing, but your phone will give the final say.
-Open the torque app ($5 dollars or so on the Google Play Store) and....I am disappointed, not working, not finding the device. It would be to easy to dismiss the product as defective, so time to venture into the torque apps settings. We all know "plug and play"...especially with Bluetooth, involves a little "tug and pray".
Go into "OBD2 Adapter Settings" (this is achieved by pressing the menu button, then selecting settings, on your ANDROID device).
-Connection Type (Set to Bluetooth)
-Select Bluetooth Device (Select your OBDII Device)
Change Preferences as you see fit, I have ONLY the following checked:
-Auto Bluetooth On/Off
-Only if BT was already off
-Use Vehicle Fuel Level Sensor
I didn't select any of the faster this and that settings because I found it was pretty damn fast as it is, and being a "on a budget" scanner I don't want to push it any harder than it needs to, I also would suspect this may effect your phones battery drain.
For turbo owners, you may have to play with the "Boost Calculation Method" setting to get the most accurate for your vehicle, is also a good way to check for boost leaks I'd imagine.
At this point you go into the gauges and start exploring...
Where's Coolant, Oil, Battery Volts, knock retard? To add those, add the GM PIDs!
Additional Settings
Manage Extra PIDs/Sensors
-Once there it will initially be blank
-Using your Android menu key select "Add Predefined set"
-Select Pontiac/GM etc.
Unfortunately from the research I've done, our vehicles don't send (at least 1.8Ls) an actual Old Pressure number, just a "yes its good" or "no its bad" on a switch type setup. No PSI for you.
As always drive safe!
http://www.youtube.com/watch?v=PoPgDT2iiag
Remember, heat is what kills most electronics.
Vehicle Info:
Hardware:
-VERIZON DROID4
Software:
-Torque Pro
-Turn on Bluetooth
Additional Settings
