pwntbywombat
Frictional losses are also responsible for excessive fuel consumption in cold weather. The cold engine oil, transmission fluids, differential lube, wheel bearing grease; all contribute to increased resistance, thus increased fuel consumption. Also the loss of tire pressure due to drops in the ambient temperature contribute to excessive fuel usage unless the pressures are frequently checked and adjusted.
You are on the right track with the air/fuel theory, but there is more to this issue.
Papasonic
That ^
Side note, I average 36-42 on the highway in this cold weather.
