key1cc
Anyone try jacking up their Sonic's rear tire using the stock jack apparatus?
(I have a 2013 LTZ hatch with 17's.)
I tried using the stock jack today unsuccessfully (to install rear Rally Armor mud flaps).
The manual states that the jack locations are marked with "1/2 circle" notches at the suggested jack locations under the car. So far so good as I was able to easily locate the notch which you will see in my attached pics.
When I positioned the jack the "stardard way" with the turning mechanism facing me to allow for easy rotating and lifting I encounted the first flaw.
Picture 1 shows the jack near my rear passenger tire in the appropriate location. Picture 2 shows that the jacks arms encounter obstructions of plastic molding on both sides while raising....before the top of the jack even touches the car. I stopped turning the jack at this point because I did not want to crack/break anything. Pic 4 just shows I would have had to keep raising the jack another 2 inches right through the obstructions if I wanted to use it this way. I did not.
Key1
Key1
