D2 Racing Coilovers
sonic007
Eric Smit
Enforcer
sonic007
Dave@ddmworks
Supporting Vendor
iraqivet
Banned
The front strut mounting bolt holes are slightly different also. Also the spring rates for a Cruze and the Sonic would not be the same.
the rear is the same. the spring and shocks will mount right up and the front is 14mm for the sonic and 12 mm for the cruze just drill out the bolt holes on the bottom of the front strut and get shorter endlinks and they will bolt right in.
and for the spring rate. on my cruze bc coils i got them from modern performance and they were the prototypes for the us spec cruze the front spring rate was 336lbs and the rear was the same
now the cruze kits us 336 lbs in the front and 236lbs in the rear i beleave.
the sonic handels just fine with them
