Vanessa,
My alignment is also out, can I find somewhere in writing about having the alignment converted under warranty?
Guys it's not the shop trying to blow you off with the 2013 specs not being loaded. A hunter alignment system requires the year/ make/model to even begin comping the car. There are work around for it just to check it but if you wanted to set it you would need specs and even all data and Mitchel don't have specs out. I had to wait to check mine and we own 5 shops.
KGB Pilot125,
Maintenance
All vehicles require periodic maintenance. Maintenance services, such as those detailed in the owner manual are the owner's expense. Vehicle lubrication, cleaning, or polishing are not covered. Failure of or damage to components requiring replacement or repair due to vehicle use, wear, exposure, or lack of maintenance is not covered.
Items such as:
- Audio System Cleaning
- Brake Pads/Linings
- Clutch Linings
- Coolants and Fluids
- Filters
- Keyless Entry (or other remote transmitter/receiver batteries)*
- Limited Slip Rear Axle Service
- Tire Rotation
- Wheel Alignment/Balance**
- Wiper Inserts
are covered up to the first maintenance inspection period outlined in the owner manual. Any replacement at the time of, or beyond the maintenance inspection period is considered maintenance, and is not covered as part of the New Vehicle Limited Warranty. The New Vehicle Limited Warranty only covers components when replacement or repair of these components is the result of a defect in material or workmanship.
* Consumable battery covered up to 12 months only.
** Maintenance items after 7,500 miles.
Louis (assisting Vanessa)
GM Customer Service
