2200 miles 1.8l motor.
Oil came out a little dark but clean as a whistle. sometimes your 1st oil change looks a bit like metalic paint with all the aluminum swarf in it....not this one...not a speck in the oil nor the oil filter.
Drain plug is a 30 torks head and it is horizontal at the bottom of the aluminum oil pan. only 14mn on it and it is labeled right on the pan...do not overtighten!
Oil filter is a simple canister element that for some reason is more expensive than a steel cased filter element with a drain back valve that is obviously more expensive to manufacture??
This type of filter will let you see everything whereas a steel cased filter will show you nothing unless you cut it open.
All in all....looks like we got a good motor.
