There is slot of porting potentialI spoke to dave this morning about cams. There is an oil passage in them for the VVT system and nobody will make blanks yet.
The conclusion about more displacement is that the cylinder walls are already thin and there isn't much room for boring. Maybe .020".
Here's the exhaust gasket against the head.
You can see the potential for porting. But rumor is the intake ports will provide the most benefit from porting.
It's oddly satisfying, just knowing where something like the thermostat is. When I'm driving and my coolant temp gets a little high, and I'm waiting for the thermostat to cycle, it's nice to be able to visualize exactly where the event is taking place.
I cant get over those temps.. that's hot as ****kk, new cars are more confusing.. could we run no thermostat like I did on my old car? computer would probably flip ****.. lol and pre.. is it hard to remove timing chain cover?? did u hit any snags? I wanted to try it once but was too intimidated :sadbanana:
Another fun fact - the thermostat doesnt open just by coolant getting hot. Theres also an ECM controlled heater that'll make the t stat open earlier if greater cooling is needed under certain conditions. Normally, it starts to open at 221*F and is fully open at 248*F with no assist. When the electric assist is commanded by the ECM, it'll open as early as 194*F.
