Keep everything in order! Take a 2x6 and drill valve stem sized holes for the valves and number and put the springs on the valve (or put dowels in front of the valve for the springs) and an egg carton to match up the retainers and rockers..... or whatever else and number it all. RDSS stated why. do the same for piston, rings, rods, cir clips, small end bearings, etc.
+1 for knife edging the crank, I think it's worth 10-20hp on a 350ci chevy in the upper rev range, so it's something to consider especially if you're upping the revs. If you wanna go fancy you could have the counterweights knife edged AND cut down and filled with tungsten (or something HEAVY) to cut windage further and bring the center off mass in closer to the centerline of the crank; this makes changes of momentum easier.
Another thing to keep in mind about porting is your biggest restriction isn't coming into the head! from about the valve stem onward the air is battling worse and worse flow restrictions, opening the biggest spot of the port doesnt do much when the remaining inch decreases volume by 30% (or whatever) and makes a bend while being obstructed by a valve. You must look DEEPER into the port, pun intended
Also don't forget about shot peening, radiusing edges, and smoothing over casting marks on the block and particularly components that rotate. As long as their not done wrong all of them will increase strength by removing stress risers.
