Boost definitely magnifies the issue.
But also helps combat the issue of time. My horsepower plan involves making use of revs up to 7k. At those engine speeds, valves open and close so fast that, without the assistance of boost, air/fuel has a very small window to enter the chamber. N/a engines require a lot of flow work to encourage air/fuel to enter in such a limited amount of time.
In a boosted application, such flow work is not required (athough it doesnt hurt). This is why I'm sprung on turbo and am never going back to n/a.
Boner inducing Piston physics. Great stuff.
Agreed, the difference in piston acceleration between 6k and 7k multiplies forces aggressively. The tensile forces on the rods as pistons approach TDC is where events became scary.
From what I've read, specs on OEM internals are accurate for their application. That is to say the forged internals on our 1.4 were engineered, tested and rated for tensile and compression forces up to 6.5k, but will quickly lose the capacity to support forces above that.
This is why I have no intention of winding my stock block up to 7k. Instead I am having uprated forged pistons and rods built for my race duty 1.4 build.
And even then, if exposed to hyper-7k revs often, I'm prepared to do rebuilds every 15-20k mi. Budget tuners, don't try this at home.
I think you mean undersquare. Regardless, over vs under square is only one consideration. To answer the question of why gm went with this particular ratio, I would hazard a guess to say that it was probably to accomplish the goal of creating a low displacement engine (under 1.4 liters) without sacrificing low to mid range torque. This was probably why they chose what some might consider an undersized turbo as well. I think it is an effective design so far as that is concerned.
Still, at 3.25 inches, the 1.4 has a shorter stroke than many of these high revving hondas. Now look at the bore of this design at 2.85 inches. How does such a diminutive piston affect f=Ma? One might think that such a tiny piston would significantly reduce mass, thus mitigating, to a greater or lesser extent, the increased acceleration that results from a longer stroke.
In any event, we are talking about a relatively minor bump in the operating range, and this increase is being accompanied by rods and pistons that should be stronger than stock.
On a comical note..... I shipped a piston and rod to DDMW in the very same box my Ultragage came in. opcorn:
That's cool and all, but I certainly didn't intend to imply that bore had any impact on piston acceleration or velocity. Rather, I was just pointing out that smaller bore equals less mass flailing about at the end of the rod so far as that relates to the force equation, which really has very little to do anything.
Anyway, I think it might be a step too far to say that bore vs stroke has NOTHING to do with it. For a given displacement, bore and stroke have something of an inverse relationship. I think that we are all in agreement that stroke does, indeed, have a place in determining piston acceleration/velocity. Generally, an undersquare engine is going to have higher piston acceleration/velocity than an oversquare engine of the same displacement.
Well, if I read correctly our 1.4 is an oversquare design (stroke is longer than the bore is wide) which means it probably won't want to rev like a honda. The longer the stroke the faster the piston speed. Just like with the valvetrain the piston is traveling 0 inches per second at bottom dead center, it accelerates like mad as until it reaches the center of the stroke where it starts to de-accelerates like mad until it reaches top dead center of the stroke when it is traveling 0 inches per second. If you have two engines revving to the exact same RPM the piston speed will be faster the longer the stroke. Once again we must remember that force= mass x acceleration. (F=Ma) so the internal forces working against our oversquare 1.4 are much greater than those on an undersquare engine. You can have situations where the crankshaft and engine block start flexing, causing the engine to lose oil pressure at the crankshaft, which quickly leads to spun main bearings. (Old Pontiac 400, and 455 cu/in used to do this) if the forces are extreme or the parts not strong enough the force can pull the connecting rod apart. The piston keeps moving up, the rod goes back down, minus all or part of the piston. Next time it comes around it might punch a hole in the engine block, but the motor is junk.
Have you calculated the piston speed at 7k+rpm?
So why did Chevy put an oversquare engine in our Sonic? Well, while the design doesn't lend itself to stratospheric revving it does deliver more more torque, and torque is good!
Torque is really good.
