Way too expensive! If you are going to do the mod, you can do the custom pod easily.
I am about to pull the trigger here, going with VDO black face gauges, volts, water temp, oil pressure in the pod, then I will sweat bullets while I replicate the boost gauge install done elsewhere here on the forum. Already worried about screwing up the hole drilling of the left dash panel.
Oh almost forgot going to buy a new upper tray to make the pod.
Still undecided on brand of gauges. The Cobalt boost gauge in the dash looks like GM put it there. It is however, pricey compared to others. Can't seem to find that gauge( Cobalt) in oil pressure, water temp, volts. So what are others using for the "perfect" factory look in their Sonic.
This thread had some great ideas.
Remember you can also use small sections of 2" pipe to create gauge holders. Also, check Ebay for people parting out wrecked sonics to find the upper dash part for cheap.
I think I would go with VDO vision series gauges and use a blue LED for backlighting. Or try to find some better matching blue/green ones.
The vdo vision series is backlit, only the numbers light up whatever color light you have and the needle is orange/red. The vdo ****pit series is "side lit", the light will come from the sides in whatever color to light the face of the gauge
Um. How do you figure? What gauges in the car have the light shining on them from the side or front? The illumination will be much dimmer overall, too.
The vision series will look the best IMO. Trust me, I've owned both types. Here's a pic from my old Jetta:
What about the giant tachometer?
Mine is backlit with turquoise numbers and an orange needle. That's what I'd be trying to match the look of.
I think those were my pics of the three black PVC pipe rings. NICE work, it looked a little rough at first but the finished product turned out great! That is pretty much what I'd like to do, the only thing I would do a little different is to have the gauges be mounted lower and inset a bit, like frenched in tail lights.
