Preloader
The M32 Martyr
Where to start? I think it's best to explain the entire theory because it makes it easier to understand a system when you know what it's suppose to do/
PCV=Positive Crankcase Ventilation
Why is positive crankcase ventilation necessary?
Well the biggest reason is blow-by. Heat expansion coefficient dictates that the piston rings must have a small split in them to allow them to expand when they experience rapid changes in heat.
The crankcase isn't actually entirely sealed from the cylinder where the combustion takes place. As the piston comes up on the compression stroke, some gas/air mixture will always be allowed to "blow-by" the ring gaps and enter the crankcase. Also combustion blow-by occurs during the combustion stroke.
The PCV system is designed to not only actively remove those hydrocarbons from the crankcase where they will rapidly compromise the engine oil's integrity and attack gaskets and seals, but also it is designed to return those gases back into the cylinders in an attempt to burn them, rather than release them into the environment as emissions.
You can read about the history and how it was actually GM that first instituted the system for widerange in civilian vehicles by searching PCV on wikipedia.
A traditional PCV on an N/A engine is quite simple and effective. Fresh air is allowed into the crankcase, and since the intake is almost ALWAYS under some vacuum..... that vacuum is allowed to pull that fresh air through the crankcase removing the volatile hydrocarbon blow-by with it. A one-way or check valve is used to prevent any pressure or fuel mixture from backfeeding through the PCV. This is the PCV valve most of us are accustomed to.
Now we come to turbocharged engines and are faced with a new obstacle....
Boost.
When the intake is no longer under vacuum, but instead boost pressure, a checkvalve would close and stay closed for the duration of the time boost is occurring. ALSO, boosted fuel mixture has a much greater probability of blowing by the piston rings.
As a result, most PCVs on turbo'd applications, have a more complex two stage system. A vent for idle and low throttle operation, and a secondary vent for WOT and boosted operation.
There are a variety of styles used, but I'm just going to jump straight into ours.
Our PCV on the LUV/LUJ draws crankcase gases through the intake manifold (IM) through a port in the center between the two middle intake runners.
The crankcase gases exit the case through the head. The head collects the gases from block directly and also through passages in the valve cover.
Here is where the gases leave the head and enter the IM:
Here are some of the passages it collects vent gases through:
Now to explain the two processes. The first is the PCV during idle and part vacuum, like mild throttle situations and cruising.
Idle
(please laugh at my elementary drawings..... I lol'd)
This is a good time to show a close up of "checkvalve" in our PCV. Looking up the PCV runner in the IM from the view of the gases leaving the crankcase, you encounter a bright orange orifice. This orifice allows gases to be "pulled" into the intake path and essentially burned with the fuel mixture.
This portion is pretty consistent with a traditional PCV system. But now let's see what changes when you dig into the throttle and create boost.
WOT
(laugh it up)
Now the IM is pressurized, and that little orange "diaphragm" is pushing against those little holes. That stops boost from escaping back into the crankcase, but now the crankcase gases need a new exit.
Look again and notice the port at the top of the IM before the orange check.
That is this big nozzle:
It runs via a tube directly to the inlet of the turbo compressor:
There is a considerable amount of suction coming from the compressor, and that is what pulls the crankcase gases (which are substantially greater during high RPM boost) from the PCV.
I hope that was comprehensive. I've wanted to do this write-up for a while because the PCV comes up a lot in troubleshooting discussions. Especially when it comes to "puff of smoke" problems.
I expect that topic to be addressed soon, but this thread can be references where PCV is concerned.
Boost.
Idle
WOT
(laugh it up)
