robinsonmac
I noticed today while playing with the traction control, that my engine is more responsive when pressing the gas with it off. I have a LT , 1.8 5 spd.
Would you have to do this procedure everytime you turn it on, or will it keep a memory of it being off??
if you want it fully 100% disabled press and hold...then pull out the ABS Fuses
ABS can do a better job because it only pumps the slipping wheel and tweaks the vehicle in the direction your turning on vehicles equipped with stability control. Panic situations, I'm not talking auto cross or on the back roads where your planning a heavy stop.
Mashing the pedal to the floor and staring at the object in front of you isn't going to help with or w/o ABS.
Most of the time a good tire combo and brakes you'll wont even hear a peep out of the ABS if your braking correctly and its like a silent partner for good drivers.
Then there this....
I'm sure laborsmith has experienced the old winter time "tap the brakes" and ok "we're not stopping for this red light" and you kinda just make your way through before the others go green and everyone is slipping to get going anyway...and the next light you stop even farther back and still end up in the intersection.
