1.4l_of_fury
zzp cold air intake, NO it doesn't have the heat shield, paid 240 new for it, only has 5k miles. Would really like it gone seeing as it doesn't fit the mazda sitting in my driveway.:blankface: 180 obo
The insert doesn't straighten the airflow...it is there to reduce the tube diameter to stock size at the MAF sensor. The reasoning behind this is to offer an intake that you can still run without a tune. I assume that is what you plan to do.The guys insert that straightens out the air flow for the MAF sensor is what I am referring to.
On the gen2 zzp intake that I had...the insert was made out of a blue plastic material. It slide into the filter end of the tube and had a cutout to fit around the MAF sensor.
Shouldn't be a hard thing to spot.
If you're interested, I am gonna have a zzp intake coming up for sale soon. I can give you first dibs.You said you'd get back to me man...
