Speaker Wire to rear speakers (back door)
So I ran my ground wire and grounded it. I have ran my power wire and have it ready to attach to the battery. I have my RCAs ran and spliced into my speaker wire (directly from HU). I had pre-run speaker wire so now I'll go into more detail about getting the speaker wire through the door harnesses and into the doors. I’ll start with the rear because they were not as bad as the front.
1. The pre-run speaker wire, (I used a high quality 14 gauge wire – probably overkill, I think 16 gauge would be fine. I would avoid 18 gauge and up if you will be using 75+ watt RMS, I don’t want to start a discussion on “minimum gauge requirements”. I’m sure you could use very very small wire and be ok in some applications.) is waiting to be run through the door harness. Starting on the front driver’s side, move your driver’s seat as far up as you can. If you haven’t already, just grab a hold of the plastic piece that runs from floor to ceiling in that pillar area (B-pillar?). Pull hard starting at either the top or bottom and you’ll be able to remove it without any problems. There is nothing to disconnect.
2. Even with pictures this next step would not be clear so I’ll describe what I did as best as possible. There is a plastic wire harness in the door post, surround by a rubber rectangular shaped seal. Use a small flat screwdriver and gently pry the seal away. The rubber, once removed will reveal a black rectangular plastic piece that is the frame of the wire harness. With the seal removed, you can pry off the rectangular piece by applying pressure with your screwdriver to the tab on top. Pull away from the car, starting with the top and then the bottom. The gray plastic harness will be what is left. It is very difficult to get to reseat properly so I’ll digress in step 3 on what to do to make sure it seats properly when you put it back together.
3. At this point, I went ahead and pre-reattached the rubber seal to the black plastic piece. Stretch the rubber all the way over the edges of the black plastic so that the edges of the black plastic are completely inside the rubber. It is very tight to work with your hands so be patient. If you don’t pull it all the way over, it won’t seal properly and there will be gaps. Once it’s fully pulled over, just let it hang on the wires.
4. Look at the top of the wire harness where you pushed down on the tab. There will be a small hole above the harness where that tab just came out of. This will be the area you push your speaker wire through. If you need help feeding it through, take a metal hanger, use electrical tape to attach your speaker wire and gently feed through. Be patient, take your time. Don’t rip the wire through, it could tear on the sharp edges of the frame. Once through, feed out just enough speaker wire to be long enough to feed through the rubber piece below into the door.
5. The rubber harness that houses all the wires transferring from the door to the B pillar is very tight. You can’t just feed your wire through. You’ll need to pull it through. I put my hand inside the speaker opening and pulled the rubber out of the seal on the door. Just enough to allow it some more flexibility. I cut a piece of wire hanger about 12 inches long. Starting inside the door I worked the wire up the rubber tube until it poked out the other side. With a few inches of wire sticking out both ends, I attached the end of the hangar to my speaker wire with electrical tape, trying to make it as thin as possible. Just pull back gently and work the speaker wire through the rubber. If it gets caught up, don’t jerk, massage the rubber where it is getting caught up and the wire will make its way through. Because the rubber is ribbed, there are lots of areas for it to catch. Again, patience so you don’t tear anything you don’t want to. As soon as the speaker wire reveals itself, pull it out about a foot or so. You can go ahead and attach your speaker connectors and let sit for now.
6. Gently manipulate the speaker wire you just ran so it is completely untwisted and as flat as possible. The goal will be for the section of wire to be flat and right where it goes above the gray plastic harness. Pull back any excess wire. First, put the rubber seal back into position into the door itself. You just have to work the rubber around the edges until its flat all the way around. Now, the rubber seal and black plastic ring should be back in one piece. All you have to do is work it back to the B pillar, slip the bottom tab in first, then slowly fit the top tab back into the B pillar hole. It will be a VERY tight fit with the speaker wire. I tried to slide the edge of the speaker wire under the plastic tab as opposed to let it sit against the sharp edge of the car just to avoid cutting the sheathing. I don’t think there will be any movement once you get this back in so I wouldn’t be worried about the sharp edge wearing into the wire. Shove the tab in as hard as possible (without cutting the wire) and you should be able to work it into place so it latches. If you see large gaps between the seal and the B pillar, you didn’t attach the seal right. It’s almost impossible to fix when it is in place, so remove the seal and frame and put together fully before trying to reattach. If you can’t get the seal flat….you are doing something wrong. It took me a while to figure it out and I was thinking there must be a special tool, but once I understood, you can get it to seal properly if you put together the right way. Now that you know the length of your speaker wire, you can pull it back and cut off any excess before where your amp will be.
TIP: If you think you can get away with smaller gauge…do it. It will make the process of running these through the doors.
Repeat for the passenger side door. I will upload a few pics later.
