How do I take that off of the wheel?Painting with a brush works well, I'd recommend just removing the bracket and caliper when painting them though. It's 4 easy bolts (2 for caliper, 2 for bracket) to remove, then you can paint the bracket off the car, keep the caliper attached with the brake line and get better coverage than if it was still on the wheel too.
On the back of the caliper/bracket, there will be two bolts (I believe you need an allen wrench for them) holding the caliper to the bracket, then two bolts (standard metric) holding the bracket to the hub. You can pull the bracket off, clean it up, and paint it.How do I take that off of the wheel?
