2014 Blue RS
I got a lean code after uploading the latest tune. I turned it off. Car is running great and getting 39.7 mpg with mixed driving.
Did you ever figure out the shifter button problem? I'm getting the same
Sent from my iPad using Tapatalk
It's defective plastic. Chevy won't recall and they'll try to make you buy the whole shifter for upwards $300
2013 1.8 hatch MT, Doubt I will make the list as I will only hit 50k this week. Although as of December 2016 I am driving 160+ miles a day.
2012 6 speed manual turbo- 155,000 miles. The car is falling apart. Turbo went at 50,000. Valve cover replaced, 3 sets of sway bar links. links are gone again as well as the shocks. Coolant issues, airbag light is on now as well, multiple thermostats replaced. This car was the worse thing I have ever purchased. I should have learned my lesson seeing I have owned 3 chevys now. Never again!
2013 Sonic RS - 137,xxx miles
couple of warranty recalls - emissions sticker, pcv related
major issues - none
minor issues - oil pan gasket (poor attempt by a Chevy dealer to fix it), PCV issue fixed by Chevy dealer (really cold weather, closer to 0 deg, the car would sometimes puke fumes like crazy, white fog when it happened)
currently car has a noise in the dash area, researching that as it's a little intermittent but has a consistent/repetitious noise when its there; maybe a regulator of some sort?
My sonic isn't high mileage, but I'll list the problems I've had.
2012 1.4 LTZ manual. 50,000km (30,000mile)
- 1 water pump
- 3 sets of end links
- oil pan gasket leak (resolved)
- crank shaft seal (resolved)
- heated seats randomly shutting off(resolved by dealer)
- radio shutting off(resolved by dealer)
- rattle from rear end below 0*C (unresolved)
- still have a coolant leak somewhere
Hi! how did you resolve your oil pan gasket leak? I think I might have that on my 2012 with 60k+ miles. I noticed it the last time I got under the car about three weeks ago. Not sure if it was oil, but it seemed to be coming from the oil pan gasket so I'm assuming it is.
