Hey guys, need some advice. My Airbag readiness light is staying on in my 2013 Sonic. And I can't get a sticker. It's not throwing an engine code, but an airbag light on will fail inspection in mass.
I took the seat out to check the connection under the seat, it's clean and tight.
I've already checked the knee airbag connection(common problem on Chevy Cruze) and it's tight. I checked the ground/ground nut and it's tight. I didn't open the airbag, but how do I tell if the airbag is bad? I did get the light to go off, but I realized the wire wasn't in right, and I had to unplug it, remove the airbag to slide the wire back in right, and reconnect it, and now it won't go off. Is this the knee airbag that has faulted? Is there a voltage or a resistance reading that these can be bench tested to see what failed?
I think it's the passenger air bag(one of them), because the little yellow light in the console shows the passenger airbag isn't on, no matter how much weight is on the seat. Unless someone here has something to add to the contrary?
There's a lot of threads on the site, but no one has posted a solution, that they found fixed the light.
HELP!?
I'm at the point it'd unplug the light, if I could. But there's probably a fail safe to prevent that.
HELP!?
