dbratboy92
I see allot of posts about after market gauges. Personally it never bothered me that my sonic only had a idiot light, until I had to replace my cylinder head because the light never turned on. Upon repair I learned why the light never turned on. Because both coolant temp sensors on the car are insulated from the engine in plastic housings. One is in the outlet housing and the other is in the t-stat housing. What that means is if there is no coolant in your engine because of one of the numerous leaks that 1.4 liters are known for, as the engine heats up the sensors will actually cool down. This is basically a PSA. As a dealer tech I highly recommend adding an aftermarket gauge. But I don't suggest putting one inline with one of those splice adapters,or tapping of of your current temp sensors. You need a gauge that comes with its own form of sensor and that sensor needs to be either in the block or
Head. So if your engine has no coolant the gauge still heats up. An oil temp gauge isn't a bad idea either. There are definitely more places to mount a oil temp sensor than a coolant temp on the 1.4 has anyone done this if so where did you mount your sensor? And what hardware did you need.
