jeff@racerxfab
Supporting Vendor
We started on the intake manifold roughly 2 weeks ago and we are well underway with machining components for our prototype manifold. From our CAD data and flow analysis, it appears the OEM intake manifold is bias to cylinder 1. We have done our best to correct for this with our current design. Does anyone know if cylinder 1 tends to run a bit lean and cylinder 4 a bit rich?
From our previous experience building turbo intake manifolds we typically like to see a plenum volume of 1.5 to 2 times the engine displacement. The intake manifold we are building falls right in between those assuming it will fit. The runner length will remain close to OEM, and the diameter is designed to work with the intake valve size.
PCV:
We are open to suggestions on the PCV routing. The flange incorporates a NPT thread which we plan to reroute to the back of the intake manifold including a check valve. From what I have read, the PCV is a common issue on the OEM intake manifold so if we can correct that now it would be great!
Vacuum ports:
We will be incorporating several of the OEM fittings on the top of the manifold. Are there additional NPT ports that you guys would like to see? We typically add a few 1/8 NPT, 1/4 NPT and sometimes 3/8 NPT.
PCV:
Vacuum ports:
