K-Bob
15,000 miles on my 2017 and no problems.
Just did tire rotation. Turns out you need a tire sensor relearn tool.
Just so you guys know: The $20 one from Amazon works just fine, no reason to spend more.
Have purchased the GM Performance FE3 dampers. Should get those installed in a couple of weeks. Will let you all know if they actually change anything.
There are a couple of annoying things though:
1.
No power outlet anywhere near the windshield and the one provided is not switched, so cannot conveniently plug in radar detector, GPS, or camera. I can't believe GM did that.
But I am planning to install an auto-dimming mirror, so when I do that I will also run a power feed up to the camera as well. It will be slick to have a hard-wired camera.
2.
No tempurature guage. Does this bother you guys? I really like to know when the engine is up to temp, esp in winter.
1.
2.
