I think these were the correct rotors to use.
They are for a 2009 to 2012 Dodge Journey or Dodge Grand Caravan. The center bore is a little larger so it may end up needing a concentric ring to keep the rotors centered on the hub. Or possibly drill the stud holes tight enough to not leave any play when the rotor mounts up. The tapered hole for the hex set screw to hold the rotor to the hub isn't on these either.
These are basically the same thickness as the Camaro rotors and about 2mm larger diameter so the pads aren't riding on the edge. They should have the correct offset to center it up when using the Encore bracket too.
https://www.rockauto.com/en/moreinfo.php?pk=3960792&cc=1444632&jsn=477&jsn=477
CHRYSLER TOWN & COUNTRY 2008-2016
DODGE GRAND CARAVAN 2008-2016
DODGE JOURNEY 2009-2012
RAM C/V 2012-2015
VOLKSWAGEN ROUTAN 2009-2014
Type Vented
Diameter (mm) 302.00
Diameter (in) 11.89
Height (mm) 38.00
Height (in) 1.50
Nominal Thickness (mm) 28.00
Nominal Thickness (in) 1.10
Minimum Thickness(mm) 26.40
Minimum Thickness (in) 1.04
Hub Hole Diameter(mm) 72.50
Hub Hole Diameter (in) 2.85
Stud / Stud Hole Size 14
Studs 5
Bolt Circle (mm) 127.00
Bolt Circle (in) 5.00
