I'm new here so sorry if this isn't the right place but I'm at my wit's end - this is the only place I've been able to post anything - if possible mods please relocate to the proper location:
I have a 14 RS 6-speed 65K miles
At about 60K miles I've started experiencing a problem with it starting when the engine's hot (heat soak). When I try to start it, it has a slow crank for a couple of seconds and then starts up and runs fine.
Once the car sits for 45 minutes to about 5 hours seems to be the window where the problems happens. Before that time it doesn't seem to heat up enough and after that it seems to cool down enough to start fine.
Car has never thrown a code.
I have a trifecta basic tune, KnN filter only.
I've replaced the battery, purge valve solenoid, plugs and wires and have had a throttle body cleaning done.
I've had it to the dealer. They had it for 4-5 days and said nothings wrong other than a plastic bracket broken under the air intake that caused the engine to shake when started :blankface:
I've had it to a local shop twice and they have no idea what's wrong - they said will have to start replacing things until it's fixed.
Any thoughts, ideas or suggestions would be great.
Again, sorry if this is in the wrong place but I can't seem to post anything else anywhere on the forum at this time.
