YouBeTailsIllBeSonic
Does anyone know if some of the other options for calipers mentioned actually work? Or is it still just hypothetical at this point?
Sent from my SM-A520W using Tapatalk
Does any one know if the 17" LTZ wheels clear the Camaro brakes? They seem to have specs of 6.5Jx17 ET41.5 so they should be ok but I wanted to double check with you guys; it seems most of pictures I've seen here have been of Sonics RS so the wheels were different. Thanks.
Yes they fit fine, I have the Zspec LTZ wheels for summer and they clear fine.
Pretty simple prospect. By the looks of his pictures 0.1" was either a bit too much or not quite enough..(I cant remember which one.)...either way if you bolt it up you should be able to get a decent measurement from either side of the rotor. Apparently Grand Caravan rotors are the perfect offset and merely need to be re-drilled. Thats what I plan to do when I can get around to it.Thank you! So I have the new Camaro brake calipers and bracket (https://www.amazon.com/CKOE00964-Premium-Semi-Loaded-Caliper-Assembly/dp/B019NUHKC8) and I have an original Sonic caliper and bracket for reference. I am trying to see how milling out 0.10" inches from the new Camaro caliper brackets' mounting hole surface will make it be centered with the 2014 Encore rotors; I will take pictures later on and show you guys what I mean. I saw the previous posts on how another user here did his but I want to make sure that I "measure twice, cut once".
Also, encore dust sheilds will fit. You only need to drill one hole
Had a little fun and painted mine
