So I've got a 2013 Sonic with just under 65k miles. A couple months ago I had to replace a cracked water outlet. Now I've got a leak on the other side of the engine that appears to be the thermostat housing leaking. I know this is a common issue but I'm curious if it's the thermostat housing that cracks or if it's just the gasket that leaks? Its $65 for the housing and only $12 for the gasket. If the housing housing had a lifetime warranty it's a no-brainer but unfortunately it only has a 1 year warranty. Any thoughts would be appreciated.
