LowGearTurbo
For best gas mileage, it is best to keep the engine RPMs low. My engine seems to run OK down to 1000 RPM (32 MPH in 6th gear), with limited power. Below 900 RPM, it seems to add throttle on its own, probably to prevent lugging (or maybe it is lugging?).
There is a YouTube video "Why You Should Never Lug Your Engine (Especially Turbos)" by Engineering Explained https://www.youtube.com/watch?v=soJea7xEt-8, with a reply by Marios EvoCy which states:
With the limited power at low RPMs, going up hills requires down shifting to 5th or 4th, unless you can keep your speed up so that the turbo gives enough power at full throttle. Gas mileage is best in the highest numbered gear that can be used. (I have an Ultra Gauge Classic for instantaneous MPG readout. )
How do these comments relate to your experience?
Although the above has a certain pragmatical basis, it is not always entirely the case. Most modern engines, with advanced engine ecu units and software, can detect knock, pinging and pre-ignition, through very sensitive knock sensor/s, catching it right just about it starts detonating, and thus reducing timing, and or richen afr at a specific load point/s.
By reducing timing and in combination with richer afr, the ecu manages to minimize to the greatest degree possible or eliminates detonation and pre-ignition completely. Also the above conditions, vary a lot from setup to setup, as these adverse effects depend a lot on the materials used and on the design of the internal structure of cylinder block ( i.e cooling and oiling), cylinder head and ancillaries, pistons and rings, inlet and exhaust manifolds, turbocharger and intercooler used, degree of cylinder pressures and heat produced. It's not about how early in the rev range boost is introduced, it's about how much early boost is introduced and if the rest of the setup/engine can cope with it. On some engines these effects are severe, on others, are almost non existant.
Also I do not agree with the comment about the colder range plug not working, as it does.
