Alright folks, ...
1.) I have updated the parts section with the new gold plated pins. These did solve my intermittent connection issues. The gold plating just adds a bit more meat to them, and they match up perfectly to the stock coil pack pins now.
2.) I more/less completed the mounting solution today. It just needs a little grinding/wheeling and then it should be ready. I am leaning towards painting it vs. powder coating just in the name of saving some money. I have a bunch of rust bullet around too, so I can use that.
I didn't realize I was out of argon, so I had to use my MIG and.. well it could have turned out better, but it'll do. I'll copy/paste what I put into the guide below.
3.) I need to figure out plug wires now. The LS3 style truck wires I had laying around are too short by about 2". There are some longer OEM wires out there, I just need to swing by the parts store and see whats going to work. I think the Escalade wires should work, they are 10".. if not there are other options that are longer.
Too short:
EDIT UPDATE: I went to the parts store, and AC Delco 748HH will be perfect.
Anyway, its getting close...
This is one of those things you will have to do according to you skill, and what materials are available to you. I kinda whipped this up quick in a couple hours with hardware store steel and my MIG welder. I do not claim to be a master fabricator, so laugh away.
What I did was re-use the stock coil mounting bosses on the top of the cylinder head. As you can see, I just used some flat steel to hold my coil bracket. I then welded on a couple ears diagonally to ensure they would clear the nearby spark plug wells. Then to those ears, I welded on some tube steel to the length I wanted for the bolts to go through to the head.
At first, I was going to make some elaborate rear bracket to use the fuel rail mounting bolts. After looking at it more, this seemed really unnecessary. So I used some rubber standoffs and the weight of the coil brackets + coils allow it to sit firmly over the intake cam area of the cam cover. I tweaked the tubes+arms back a little to make it act like a spring, and its pretty rock solid.
The pictures kind of explain the rest, but I countersunk the coil bracket holes so the hardware wouldn't rub against the cam cover.
The way I made this, I should be able to utilize a couple commercially available covers (with modifications) and I think it'll look okay.
My plan is to either paint or powder coat my mount gloss black, I am not sure yet.
