Hello all, I own a 2012 Chevy Sonic Lt with a 1.8 4 cylinder motor. I have been having issues with this car having exhaust smell coming into the cabin. I found an oil leak coming from the valve cover, fixed that with a brand new valve cover and gasket. No more oil leaking coming from there. Looked on line and saw people saying the oil cooler gasket can leak. The gasket did indeed look bad. I changed the gasket and then reassembled. I am still having the problem with the smell of exhaust coming through the vents. Especially when I have the heat to cycle the whole vehicle and the heat directed at the floor. I than changed the cabin filter. Still did not help. I replaced my exhaust where it was cracked and broken already. I do not know what to do now. I am at a stand still.
Ps. ALL the issues started when my coil pack went out, and was causing alot of miss firing. I think that is what caused the valve cover gasket and oil cooler gasket leaks. It was knocking hard and I had to drive 15 miles to the auto store, because I was traveling in a very rural part of Michigan. WHen I replaced the coil and spark plugs no problem. Noticed the leak and smell after my trip. I have 121,000 miles on the car. The engine sounds great, and drives well, but that smell is bad.
Hope you can help.
Hope you can help.
