Generic P0011 fault code, replaced vvt solenoid, timing sprockets, set the timing, and no improvement. I suspect oil pressure issue to the solenoid, and am going to try replacing the oil flow control check valve, looking for advice or similar experiences. Have found very little information on replacement of oil flow control valve. But it's different from the oil pressure relief valve in the bottom of the oil pump. Please help
