I bought a 2013 Chevy Sonic LT manual transmission from a used car dealership with 131,000 miles back in 2020. It's now almost at 142,000 miles. I've always assumed that the timing belt had been replaced by the previous owner, but I just re-checked the Carfax and it doesn't have a record for timing belt replacement. The last maintenance record with the dealer before it was sold was at 93k miles, when the evaporative solenoid was replaced -- the timing belt is recommended to be replaced at 97,500 miles.
FWIW, when I bought the car, the mechanic who checked it told me to have the used car dealer check the "pulleys" for this noise in the engine. I told the dealer to fix the problem, and his mechanics ended up replacing the alternator, which fixed the noise problem.
The vehicle is now turning 10 years old, so if the timing belt hasn't been replaced, I have to have it replaced ASAP. But is it even possible for the original timing belt to last this long? For all I know, the original owner might have had it replaced at a non-Carfax affiliated shop.
Hi,
I just changed mine at 60k so I have a bit of insight. First of all, the factory belt was already stretched by at least a full cog. I would expect a lot of belt stretch by 150k and it would probably be enough to retard the cam timing and trip a code. But also, this stretch will be noticeable in the alignment of the cam gear - which you can use to check if the belt is old without taking off anything other than the valve cover, which is like a 15 minute job and requires only one tool - an E10 socket. Everything else clips together.
* The wire harness trays slide up and off
* The PCV can remain attached.
* The spark plug/coil pack cover pops off.
* The throttle body plug as a safety tab on the release lever that has to slide out a little before you can push on the release lever.
* To disconnect the coil pack, there's also a little tab on the connector where the push-to-release lever is. It slides out to the right
* Don't forget to push these tabs back in when you reconnect those things later.
* To unplug the coil pack you want to wiggle it out gently with the release lever pushed down. It will be tight because there's a rubber dealy to keep dust out. Just wiggle a lot and it will come.
There are two E10 bolts holding down the coil pack. These come right out - don't lose them. Wiggle front to back on the coil pack while pulling up over each plug and it will lift right off.
Remove the upper timing belt cover on the left side of the head. There are two E10 bolts holding it to the head and they come out - a magnet is handy if you think you may drop them. Getting them back from under the engine would be difficult. A good trick is to tape a magnet under the hole while you are removing or reinstalling them - especially if you're like me and drop half the bolts you handle.
Loosen all the other E10 bolts holding down the valve cover - these ones don't come out all the way, they stay in the cover.
On the left side of the valve cover there's some thicker plastic you can pry on to pop the cover off. Don't stick anything between the valve cover and the head - you'll scratch the head or damage the gasket. There are lots of spots to push/pry on and it doesn't take much force to pop the cover off.
You should be able to reuse the gasket if you're gentle, but you might want to grab a spare just in case. There is no magic to installing a new one - they are held in place by a groove on the cover and there's nothing to line up or anything like that - anyone can do it. If the old one didn't come off easily or tore easily, it was time for a replacement anyway.
With the valve cover off, you can see the camshafts. There are two flats on the right sides of the camshafts that are used to align them where the engine is being built.
Repeatedly blip the starter to turn the engine over until one of them is at the top. Don't worry, it won't start because there's no coil pack. If it has to go around more than one full circle, stop when you're close and take 15, have a beer, watch some youtube, whatever. This is to let the pressure in the #1 cylinder bleed off or the engine will pass the spot due to compression of the #1 cylinder. Your engine is now at #1 top dead center. If you miss it by a little, no big deal. Read on.
Place a straight edge across the flats on the camshafts. If they both line up perfectly, you have a newer timing belt. If they slope down and out but touch the straightedge in the middle, your belt is old and stretched.
*If you missed Top Dead Center due to some pressure in the hole, you can still use your straight edge to check the cam alignment. Place one end of the straightedge on the flat or get a buddy to, while looking down along the engine from the side. Find or make a spot of the wall at the other end of the straightedge. Now do the same for the other camshaft. Are the two spots at the same height? If so the cams are parallel. Gotta love triangles. If the two spots are not even close to the same height, your belt is stretched.
