Are these motors that reliable to hit that high on stock internals?
Boost pressure has little to do with strain on engine internals. Cylinder pressures reach over 200psi during the power stroke. So 23psi of air isn't going to damage a damn thing.
It's preignition (detonation) that melts motors. As long as you use high octane fuel, a good intercooler, and don't get rediculous with ignition timing the motor will stay together. If you need more help preventing detonation you can look to methanol injection.
Little motors with tiny turbos like the Sonic have to run much higher boost pressures to get a measured increase in power (less "inches" to pressurize) compared to a large displacement motor. So 20psi really isn't that uncommon.
