corbetts67
Plasti dip! White
Plasti dip! White
I don't think spacers will be needed. If you are flush now, the only thing that will change when you lower is the front camber.
It's hard to tell from that angle...when you look closer it seems like they may sit a little bit in from the fenders. I guess I'll find out for sure when it gets lowered.
you bang those wheels.
-Eric Smit
How wide are your rims? 60mm is the magic offset for flush with 6.5's.
If they are 8" wide. 42mm offset = flush.
2mins I'll do a hi res one with some banging wheels later.
FYI, the 'shoop you did does not proportion those rims as 18's. But I'm sure you knew that.
