Delay can be off. Above that, there's a PE enable, set that using the MAP value so whenever you go into boost it will richen up. Keeps it safe. Make the settings for turn on mirror the stock stuff, but use a stronger enrichment rate and lower rpm/tps points.
Also, glad you got it figured out. Tuning isn't magic when you can understand the data. Always revert back to stock and make small changes if you are unsure why you have the result you do. Also, save files between changes, so you can flash back one mod at a time if you need to.
