Roadrash987
I was searching for a turbo kit for the 1.8 sonic but could not find a traditional kit. I got in contact with STS turbo and found out that they have a bolt on kit for it. The kit starts at $2400 and comes with a 5psi boost spring that is up-gradable and adjustable. The kit will produce around 300 crank hp at 5psi. Turbo takes the place of the stock muffler. There are still things that you would need to get on your own with this basic kit like a tune, injectors, bigger fuel pump most likely, ect. Joe Loftus is the person I talked to at STS Turbo.
