8 AM drop for 5000 mile service & I have a list of items to be checked. They are; grinding into reverse, sputtering or misfiring, more than usual loss of power with AC on, crappy gas mileage & the return of brake chatter. oh and the AC vents above the radio have started to chirp like a bird and the drivers side wind noise has increased.....
Just want to Give you some helpful advice towards your A/c Problem your experiencing. I had the same problem of my car bogging and so forth, gears not shifting when they were suppose to and so on. I firmly believe the reason for these happening is simply because the stock Air Intake system is just purely too restrictive. more than most other stock units.
To help you out and solve some the the problems if not all concerning the A/c loss of power and gears sticking, and crappy gas mileage... Do this simple fix. Will require spending a little money but well worth it! Buy the K&N Air Filter for the stock box. Install it and you will be amazed at how much of an improvemnet that makes on this car. I have a DIY Thread showing you step by step how to change it in the DIY Section.
Since installing the K&N Air Filter in my Sonic, I have noticed improved Acceleration, Does not bogg anymore, Gears shift when there suppose to and dont stick hardly ever. If they do, just simply ease off the gas slightly as it hits the top of the rpms of each gear and then ease back on and it will make the transmission shift to the next gear (If you have the automatic). I have seen a huge improvement in gas mileage on my sonic. I went from using 3/4ths of a tank in one week to barely 1/2 a tank in a weeks time. and that was with some aggressive driving during that period too. So if you do it right you can have alot of improvements just with a change of the stock air filter to the K&N air Filter. Sounds odd and unlikely, but it does work. I know of 3 other people that have done this and have seen improvements in a weeks time with there sonics by just changing out the stock air filter with the K&N Filter.
Hope this helps you out. Best of luck with your sonic! I have the 1.8 LT2 Sedan for reference.
