JungloSonic
yesterday, I let the engine heat up to 113 degrees Celcius. The fan is suppose to run at low speed at 99 degrees and at high speed at 109 so the fan should have gone on at some speed but neither low or high speed came on. The only time the fan goes on is when a/c is on. I have bought an OBD scanner that shows that on board computer is receiving temp (started at 23 degrees and gradually went up to 113 as engine was running)
The fan assembly has a relay with resistor (similar to attachment)that is involved in slower speed ..Could this relay be the problem? Most of the green covering is flaking off and there is some rusting.
