suitcasejefferson
What is the best way to remove at least one gallon of coolant from my 1.4? I have finally flushed it enough that the distilled water in the reservoir stays clean after nearly a week of short trips, so I hope I've got most of the dexcool out. I'm replacing it with yellow Prestone concentrate. I want to put in one gallon of it, which will be just over a 50/50 mix. I cannot find a lower radiator hose I can get to without doing a whole lot of disassembly, and I can't find a drain. I have removed the plastic panel under the front end. Just filling the reservoir to the "full hot" line takes almost 3 qts. so it doesn't need to be much more. If I can't drain it out, I may have to remove the thermostat and blow it out with compressed air.
