There are many causes of hard starting but illustrative ones are a faulty engine coolant temperature switch (sensor), malfunctioning idle air control (IAC) valve, vacuum and EGR leaks, inadequate fuel delivery or pressure (clogged fuel filter, injectors), and contaminated or old gasoline.
I tend to agree with this. General rule of thumb it’s electrical or fuel delivery. I think these cars have a built in fuel filter on the fuel pump. Generally not that difficult to replace. But I would have a mechanic run some diagnostics to be sure.
I replaced a Fuel Pump in an apartment complex years ago on a 1999 Ford Escort. Luckily these cars are cheap and easy, literally the same exact procedure and pump style. You can replace just about anything yourself. Unlike a freaking Audi, BMW etc. Fuel Pump will be under back seat it’ll pop out with out dropping the gas tank. But theirs ways to diagnose with an OBD2 scanner first to make sure it’s not MAF etc. I’d run all the diagnostics first to narrow down the problem. It also wouldn’t hurt to run a tank of 93 octane to clean things out and see if that helps. Sometimes a check valve goes bad on these fuel pumps. What happens is the gas drains back from the injectors over night or time and back into the gas tank if the check valve on the fuel pump goes bad. Means as your car sits the car has to rebuild the pressure meaning the pump has to work hard to bring the fuel back to the injector after sitting causing a hard start. That’s pretty typical.
Lol you can fix it pretty easy. The Sonic is old school. It’s not like today’s higher end pain in the ass cars and High Pressure ****. So you should be able to fix it fairly easily and quickly you just want to check all your boxes.
I’ll give you a simple test to see if it’s a check valve on the fuel pump
After letting the car sit over night. Before you turn that car on go to accessory mode. Turn the key all the way with out starting it wait 10 seconds. Do that again 3 or 4 times with out starting it (more Dosent hurt). What your doing is priming the pump. If it starts immediately after doing that then your check valve is bad on the pump. Either deal with it or replace it.
Thank me later and let me know if I was right cuz if the car starts right away after sitting a long period when it normally wouldn’t after doing this test that’s guranteed your problem.
