After looking through about 100 pages on this forum, the most I could come up with is a bunch of people asking for a phone mount that fits in the ticket holder, one homade mount, and another brandless one purchased from walmart.
Without anything to go on, and with a note 2 that limits my options due to its size i began shopping around and came across this:
Amazon.com: Everydaysource Compatible with Samsung Galaxy Note II N7100 Car Air Vent Phone Holder: Cell Phones & Accessories
pros:
-its cheap! ~$4 :banana:
-the vent hooks are the perfect fit for the ticket holder, and the hooks add some spring to make for a nice snug fit.
-you can put the phone in horizontal mode
-I doesn't cover any controls!
-You can leave the flip cover on if you use one!
-snug fit, phone isn't going anywhere
Cons:
-Cheap plastic; the hooks seem easy to break if you screw around with it too much; for its purpose its fine though! It will not break under normal use.
-you have to unscrew 1 screw to put it into horizontal mode.
DO NOT put the hooks in with the open end facing up, it will get caught inside; there is a ledge on the top of the card holder. You'll break it trying to get it out.
This particular phone charger is only for the note 2, however if you search amazon for "everydaysource car air vent phone" you will find one for just about any phone with the same kind of mount which is what is important for fitting in the ticket holder!
Hopefully someone finds this helpful!
Here is a pic of it mounted! Remember this is a note 2 mount, so its about as big as they get .
http://db.tt/ouzDWAUw
pros:
Cons:
