rodslinger
So the past few weeks I've been driving either a Sonic or a Fiat 500 as my rental cars in Miami. What I've noticed is the factory stereo in the Fiat is way better. It is Bose branded so my expectations were low to begin with but have been honestly pleased.
What I noticed is that the Fiat bose setup has this compact subwoofer setup under the passenger seat. Appears to be some sort of transmission line config. See link below
Fiat Bose Subwoofer | Flickr - Photo Sharing!
So far from what I've found is that it uses at very compact, about 4.5" driver with a .5ohm coil. Yikes. But maybe two of these in series, one under drivers seat, one under passenger seat might do the trick with a decent 1ohm stable amp.
Also seems to be a decent amount of space under the trunk liner where the spare tire should go to do something there.
If you are looking for license plate, neighbor annoying, police attention getting bass then this thread probably isn't for you. But if you just want a little clean, low end extension to the factory setup without sacrificing space then this is what I'm thinking about about.
What routes have you taken for this?
