The tubes showed up finally after a delay in the shipping. We have been able to verify fitment is great on them also. The webpage is being worked on today and we are getting all of the pricing and options up on there also.
We will have the following options for the hard tube -
- silicone color (black, blue or red)
- 1/8" NPT fitting welded to the tube for nitrous
- include block off plate (for those using an aftermarket blow off valve)
- include Synapse Blow off valve welded to hard tube
- Powdercoat color options
Let me know if there is anything else you think there should be for options.
Thanks,
Dave
You're right, intake temps read by the ecu are post-intercooler.
Usually you can just compare to ambient air temps to determine effectiveness of a new IC
Thanks,
Dave
Take my money! :banana:
ordered :banana::banana::banana::banana::banana:
i did notice it does not give you a choice of color for block off plate
Order placed Dave! Thank you for taking my money![]()
Dave, you saw that I asked for black silicone right?
Yeap, have you down for black silicone, kawi green with the 1/8 fitting.
Since we have the block off plates now for the turbo bypass, we will be introducing a drivers side hard charge tube.
The hard tube will be made from CNC mandrel bent aluminum and come standard in a polished finish. We will be offering standard and custom powdercoat options for the tube also. We will also be offering external blow off valves and will weld them on the charge tube for you before powdercoat.
Here are some pictures of the prototype running on our car, another prototype is being sent out for the production run to start and we expect these back early to mid March. Once they go into production we will also have pricing for the tube and also have combo kits that include the rest of the silicone tubes in the system.
Dave, do you any pictures of the pipe with a BOV flange on it? Just wanted to get an idea of where you are putting them.
