So the ground battery cable on these cars is a two-piece design.
The ground from the engine block is taped up with the positive batt cable, and attaches to the chassis frame rail beneath the battery tray, right in front of the transmission mount.
The second ground cable, going to the battery attaches to another frame stud just a few inches away from the first cable attachment.
This is what I consider the "flaw" to be.
Both of these cables should be attached to the same stud for maximum conductivity and minimum current resistance.
The only reason I can see for why they separated them may be for assembly line convenience. One cable might get installed at a different point than the other one.
However, this issue can be improved for no money spent, and for less than a half hour of relatively easy work.
Of course you have to remove the battery and battery tray to get at them.
Basically, you just remove the cable to the battery, and install it on top of the cable end going to the engine. It doesn't really alter the cable effective length or positioning to the battery, since the cable ends were so close to begin with.
The only real alteration to the cables is to bend a small tab on the cable terminal from the engine side flat with a pair of pliers so that the cable to the battery can rest directly on top of it.
I cleaned the terminal contact sides with a piece of scothbright pad soaked with WD40 to make sure they have good electrical contact with each other. I then applied a bit of grease to them for anti-corrosion.
Now this mod won't make much difference in daily driving, but if the battery is marginal for some reason, it could make the difference between a successful start, or not, since the starter current doesn't have to pass through the chassis steel to get to ground now.
Top part of pic shows stock layout, bottom is modded.
Cable going to the top right is to the engine.
Cable going to bottom right is to battery.
