RockTheShazbot
DISCLAIMER: I am not responsible for any damage cause to your vehicle. If you don't feel comfortable doing the DIY shown below, then take it to someone you trust to work on your vehicle.
Difficulty: Easy
Time: 5-10 minutes
I personally hate the look of front license plates, so I took off the front bracket. When I first looked under the dealer ad, I thought they were a proprietary screw. After trying to screw them out, I found out they are in fact rivets. Only tool you will need is a small pry bar.
Here is the before pic.
Here are the rivets
Here is what the bracket will look like after you pry off the rivets. Even if you want to put it back on later, the damage that you WILL DO to the bracket doesn't matter because it is going to be behind a license plate anyway.
All done!
There will be holes left in the plastic part. Cover them however you want. A big piece of vinyl, bondo and paint. I am going to run to Autozone and get plastic plugs (like what holds together some body panels and interior pieces and such)
Edit:
Got around to going back to Autozone and buying plastic rivets to cover the holes.
Difficulty: Easy
Time: 5-10 minutes
Here are the rivets
All done!
Edit:
