Gear Shift knob button stuck in
photon
SonicBoy24
seanp1
photon
SonicBoy24
Swordsmith
242hp/252 ft-lbs BNR EFI
seanp1
Swordsmith
monzaruba
Site Supporter
Swordsmith
Luv2xlr8
monzaruba
Site Supporter
Dylpicklee
Has anyone tried the manual key release underneath the ignition switch when the shifter is jacked up and the key can't be removed? It is described in the US owner's manual section 9-15.
Vehicles with an automatic
transmission are equipped with an
electronic key lock release system.
This system is to prevent ignition
key removal unless the shift lever is
in P (Park).
The key lock release will not work if
the battery is charged less than
9 volts, or uncharged. Try charging
or jump starting the battery. See
Jump Starting on page 10‐74.
If charging or jump starting the
battery does not work, there is a
manual key lock release. Locate the
hole below the ignition lock. Insert a
tool or key into the opening. Locate
the lever, and press it toward the
steering wheel while removing the
key from the ignition.
Not sure if that will help, but it's worth a try.
monzaruba
Site Supporter
