Right on!
I've been thinking of installing one of these connected to the licence plate circuit, hitting the road at the back of the RS when the lights come oni can see this in my near future...Maybe when i install my oracle GOBO
Cost of repair and replacement makes it way more than $0.02 but I get your pointWow, that would have cost GM like $0.02
Cheapskates !!
It's two wires to connect. 12vDC is super easy to work with. Drill a hole, route the wires, wrap connections with electrical tape.... DoneThat's awesome. I want that but I'm not good with stuff like that though
Regardless of what you are doing it's two wires to connect, 1 power, 1 ground.depending on how you want them to work.....
I will be going to the BCM and picking up an open door signal
The switch module has 4 tabs. 2 on each side. Just use a small pick and unclip them. I did the passenger side as a test and it came out quite easily.
Sent from my SM-G925F using Tapatalk
