I'm happy with my '12 1.4t MT hatch, but the glove box has started falling open. It closes perfectly and the door is aligned in the opening it looks like, but is there a common fix for this? I did search before posting and only found 1 mention of this but no discussion. I'll put fix here on this thread, but hoping someone already had figured it out.
I don't know if this is a fix, but it worked for me....
I had a water issue on the passenger side, so when ONE dealer tried to fix it (three times) They would have to remove the glove box to look up into the back of the dash as well as remove a filter in there. Well, when they put it back together, that's when I started having my glove box randomly pop open.
I ended up emptying the glove box myself, removing the rubber thing on the side and letting it drop all the way to remove the whole glove box. Then I put it back on in reverse order.
1. Make sure filter clips are closed correctly, holding in filter.
2. Re-install/Re-seat glove box.
3. Attach rubber holder on right side.
4. Close it.
It seemed re-seating it helped because it hasn't happened to me again since.
