I've done transmission flush once, replaced rotors 2 times. I believe the first time they went was about 80,000 and they were giving an awful vibration when braking. Replaced recently because my caliper seized and burnt one so those were done to. Replaced cabin air filter once. Purge valve, alternator not long ago as it was making a weird bearing noise, thermostat as it went about 2 years ago. Sway bar links replaced with moogs when I first got the car. Honestly nothing major really. I'm at almost 115,000km now. Running awesome.Did you do all those weird adduction cleanout thing and all those “suggested” maintenance things?
I’m a little over 50k on my 2016 LS 1.8 and she still purrs like a kitten [emoji177]
Finally about to change my stock brakes, wonder if my rotors are done too?
124,499 Miles 2012 1.8 Hatchback LT - stock aside from listed repairs and added sound system
In addition to all the standard maintenance items such as oil change, new battery, tires, etc:
New engine/transmission mount @ 26K
Replace faulty airbag modules @ 30K
Replace front brake caliper brackets
& flush coolant system @ 31K
Replace transmission turbine shaft @ 33K
Replace intake duct & clean throttle body @ 62K
Rear brakes & rotors @ 63K
Replace hub bearings @ 75K
Replace FR CV axle half shaft @ 108K
Transmission fluid flush @ 116K
Replace spark plugs & coil pack @ 118K
Flush coolant system & clean throttle body
and fuel induction @118K
Replace same CV axle half shaft again @ 123K
Brake fluid flush @ 124K
And so much more to come I am sureStill need to fix a few electronic issues and figure out some long enduring noises and quirks.
I think it has a timing Chain ??? Don't let dealer sell you timing belt .....Do both timing belt and water pump, and soon.
Well I made believe it or not......:banana:View attachment 14692
3 head gaskets
