Swordsmith
242hp/252 ft-lbs BNR EFI
The built in MPG gauge didn't seem to be accurate when I bought the Sonic, I've deliberately left it un-reset so I have a running lifetime figure, even though I know it is probably wrong, it shows a trend.
My UG seemed pretty accurate at first, but with mods it has become worse than useless. With the ZZP intake's restriction tube removed, it reports MPG easily 10mpg over what I'm really using, sometimes as bad as 20mpg over.
Running varying levels of alcohol, it got even worse, I've seen it report 60 mpg when I actually got 23mpg.
Discussing this with Vince of Trifecta, he said
So, is there a way to force UG to read useful data? Or is there a gauge out there I could switch to that would give this info correctly? I was really having a good time experimenting with hypermiling techniques or watching my mpg plummet as I drove Indy style
The real problem is the UG should take the AF_CALC data, not the MAF data
