Ksull72487
Well guys I want to say I have a 2019 Chevy Sonic RS. And the first thing I did aside from maintenance etc was upgrade the bulbs.
SeaLight is the brand I chose to clean up the look. Also since we have the DRL running lights stock and LED front side markers. The upgrade really pulled the look together.
LowBeam - H11 I highly recommend an HD. The newer Sonics use projectors and HIDs usually do better in them. I have a LED from SeaLight and so far so good although slightly dimmer or the reach isn’t quite as good. Not bad or enough for me to say halogen was much better.
High Beam - 9006 Reflective Housing LED works great.
Fogs - SeaLight sells Yellow and White LEDs I went with white.
Interior - 924s and one festoon bulb.
License Plate - 924 a pack of 10 of these is $8.99
Reverse - 921 on my Hatchback (much brighter and no yellow).
Brake Lights - So we are unlucky with the newer Sonic. You’ll need 4 7443s just to Cover the brake lights.
Everything I bought is from SeaLight. Is working great. Available on Amazon. I also did the upgrades in stages to test reliability. It started with high beams and low beams only.
Bare in mind. Try to stick with the same brand bulb. When it comes to LEDs colors can vary dramatically. Some brands saw 6,000k when it’s 6,500k. So the color is off now. SeaLight did pretty good for me.
SeaLight doesn’t sell a Amber Signal bulb. I’m not looking to upgrade them although. The way I figure the bulb out hyperflash tells me you have a bulb out. If you add a resistor you now have two problems. Heat and the hyperflash bulb out warning won’t work anymore. I may do it down the line. Using a resistor for a signal or a canbus system is cheating. The idea is you pull more power to make the car think the bulb is working. I’ve never been fond of it. Bulbs are usually short lived as well in my experience or problematic etc.
With a BMW that used Canbus you could recode the computer when upgrading to LED. That is the correct way to do it. Not with Canbus Friendly Bulbs or resistors. I don’t think the Sonics Body Control Module can be recoded although for the signals. So my guess is you’ll have to buy a resistor. Don’t fall for that built in stuff. Resistors get so hot you will replace that bulb more often than a regular one. An LEDs number one enemy is heat and they generate a lot of it, with resistors even more. I always try to buy non Canbus LEDs or LEDs with out resistors for that reason. You want a separate resistor always if you absolutely have to cheat the system. Food for thought!!!
People don’t know this stuff. We don’t need a canbus friendly bulb with a resistor to cheat the system. You buy that bulb it’ll gurantee fail fast. So try to buy ones with out the resistors.
With our Chevys we are lucky although. GM isn’t using Canbus. So LEDs are easy. Your only issue is the signal and with a seperate resistor it should work reliably but you’ll never know when your blinker fails.
Also people seem to think LEDs last 50,000 hrs or more. Whether that be in a TV or household bulb or car. They don’t. Heat kills them. And with LEDs they don’t just go out. They get dimmer and dimmer and dimmer. Or maybe a diode or two fails. You need to be attentive to that. Otherwise you won’t see. I keep the stock low beams in my glove compartment for that reason.
