Big Turbo Sonic
Found some good information online for when you re-bolt up your transmission/or components of the tranny that is equipped with an M32 gear box.
Backup Lamp Switch
35 N·m
26 lb ft
Front Differential Carrier Flange Bolt
• First Pass
20 N·m (1)
15 lb ft (1)
• Final Pass
45 degrees
In taking off my diff cover I noticed they use red locktite!
Oil Drain Plug
20 N·m
15 lb ft
Oil Filler Plug
30 N·m
22 lb ft
Shift Control Lever Bracket Bolt
20 N·m
15 lb ft
Shift Control Housing - to Transmission
20 N·m
15 lb ft
Transmission Control - to Chassis
8 N·m
71 lb in
Transmission Front Mount Bolt - to Front Suspension Frame
100 N·m
74 lb ft
Transmission Front Mount Bolt - to Transmission
100 N·m
74 lb ft
Transmission Mount Bracket Bolt - Left Side - to Transmission
100 N·m
74 lb ft
Transmission Mount Bolt - Left Side - to Chassis
62 N·m
46 lb ft
Transmission Mount Nut - Left Side - to Chassis
62 N·m
46 lb ft
Transmission Mount Bolt - Left Side - to Bracket
• First Pass
50 N·m (1)
37 lb ft (1)
• Final Pass
60 to 75 degrees
Transmission Mount Bracket - Rear Bolt - to Transmission
100 N·m
74 lb ft
Transmission Mount - Rear Bolt - to Front Suspension Frame
110 N·m
81 lb ft
Transmission Mount - Rear Bolt - to Mount Bracket
100 N·m
74 lb ft
Transmission Nut and Bolt (M10) - Bell Housing Nut/Bolt
40 N·m
30 lb ft
Transmission Upper Bolt (M12) - Bell Housing Bolt
60 N·m
44 lb ft
Transmission Front and Rear Bolt (M12) - Bell Housing Bolt(s)
60 N·m
44 lb ft
Transmission Lower Bolt (M10) - Bell Housing Bolt
40 N·m
30 lb ft
Clutch Actuator Cylinder Bolt (MZ0, MZ4, MF3)
6 N·m
53 lb in
Clutch Actuator Cylinder Pipe Nut
18 N·m
13 lb ft
Clutch Master Cylinder Nut
18 N·m
13 lb ft
Clutch Pedal Position Sensor Bolt
3 N·m
27 lb in
IF YOU ARE USING AN AFTERMARKET CLUTCH, CONSULT THE MANUFACTURE FOR THIS TORQUE SPEC
Clutch Pressure Plate Bolt (MZ0, MZ4, MF3)
28 N·m (1)
21 lb ft (1)
Flywheel Bolts
1. 60 N-M (1) or 44 lb-ft
2. 45 degrees
3. 15 degrees
1 = Use NEW Fastener.
Source: Vauxhall Workshop Manuals > Astra J > Transmission/Transaxle > Manual Transmission - M32-6 > Specifications > Fastener Tightening Specifications
There is all sorts of other good info in that link.
Backup Lamp Switch
35 N·m
26 lb ft
• First Pass
20 N·m (1)
15 lb ft (1)
• Final Pass
45 degrees
Oil Drain Plug
20 N·m
15 lb ft
Oil Filler Plug
30 N·m
22 lb ft
20 N·m
15 lb ft
20 N·m
15 lb ft
8 N·m
71 lb in
100 N·m
74 lb ft
100 N·m
74 lb ft
100 N·m
74 lb ft
62 N·m
46 lb ft
62 N·m
46 lb ft
• First Pass
50 N·m (1)
37 lb ft (1)
• Final Pass
60 to 75 degrees
100 N·m
74 lb ft
110 N·m
81 lb ft
100 N·m
74 lb ft
40 N·m
30 lb ft
60 N·m
44 lb ft
60 N·m
44 lb ft
40 N·m
30 lb ft
6 N·m
53 lb in
18 N·m
13 lb ft
18 N·m
13 lb ft
3 N·m
27 lb in
28 N·m (1)
21 lb ft (1)
Flywheel Bolts
2. 45 degrees
3. 15 degrees
