red_pig_ears
P0598 Thermostat Low Voltage
P0102 MAF Low Voltage
I had these two codes pop up simultaneously and found a post here that had the same issue and mentioned a blown fuse but didn't say which one.
I found a blown fuse under hood and it's fuse #23, ECM 4. I replaced the fuse and the code went away for a few moles on my test drive but the next morning they came back on startup with cold engine. The fuse is blown again. The connectors and wires to the MAF and thermostat housing look fine.
Last september I replaced the thermostat housing but have never touched the MAF. The thermostat housing I bought was an off-brand to save a few bucks but I suspect it might have a short or something that's blowing the fuse.
How can I test the thermostat or MAF to see if they are both still good? Any other ideas what could be blowing this fuse?
